widget suggestion?
jshah-3
1-Newbie
widget suggestion?
I want to develop a hierarchy structure
as follows
floor 1-
     room 1-
          cabin
          conference
          hallway
floor 2-
      room 2-
          cabin
          conference
          hallway
if I use tree widget I can select either cabin or conference of room 1
But I want to allow the user to select both cabin and conference
is their any widget that can full fill this need?
Thanks for any help
posipova
20-Turquoise
(To:jshah-3)
I'm not sure if any widget allowes multiple children selection. You may try tree grid (part of the advanced grid). Alternatively, you may look into modifying existing widgets and/or developing your own solution. Attached is documentation on custom extensibility.
3 REPLIES 3
posipova
20-Turquoise
(To:jshah-3)
ad24
1-Newbie
(To:jshah-3)
Hi ,
Try with Tree Table widget it may help you in multiselect
posipova
20-Turquoise
(To:ad24)
Tree table widget might work as an immediate solution, however, as there is no current support for the widget itself, I typically do not recommend to use it.
