with Tree Grid advanced widget facing Column Header problem
KSM
I am using Tree Grid Advanced Widget, and defined some columns by grid config service. when I run that Mashup the mashup displays weird results like column names and width are changed their position when I run each time.
Eg: column header should be display like in this order.
Name   Number    Date    Status
instead of this it will display sometimes like
Name Date Status  Number or
Number Status Date Name with irregular widths, etc..
If anybody have faced this issue please help me out
KSM
(To:slangley)
Hi Slangley,
Thanks for Reply.
Right now that problem is solved and it is happening because of may be Browser cache. If I run that Mashup in incognito then its working fine and with normal browser mode sometimes its work fine and sometimes not.
Is this permanent solution or not I don't know.
Regards
KSM
2 REPLIES 2
slangley
23-Emerald II
(To:KSM)
Hi @KSM.
What version of ThingWorx are you running?  Can you provide your mashup so we can test?
--Sharon
KSM
(To:slangley)
Hi Slangley,
Thanks for Reply.
Regards
KSM
