Hello everyone,
I have followed the tutorial and I have got the results for a predictive scoring over the scoring data subset. However, I have only got 8 printhead error over the 150 existing.
I have tried a simple linear regression and the result is worst, because the prediction result is zero error.
I don't know which parameter I must tune to get the boolean result. I suspect that it can be caused by some threshold to identify the result as one or zero.
Could you help me with the model configuration?
Thank you very much.
Hi David
One additional point of interest.
The demo json file define the PrinterHead_Error_Occurrence field as DOUBLE.
You can change the json file to define it as BOOLEAN.
The scoring result will be directly 0 or 1.
Regards
Chrisotphe
Hi David
Could you please post the following:
- output of http://<AnalyticsServer>/1.0/about/versioninfo
- the scoring result csv file for the initial model created with the 4 default learners.
Thank you
Kind regards
Christophe
Hi David
Regards
Chrisotphe
Thank you very much. Now it is working as I expected
Hi Christophe,
Here you have the requested data:
- {"implementationVersion":"7.4.0"}
The result csv file is attache.
Thank you
