As an admin, I can access wsdbprod01136-AnalyticsServer_TrainingThing but my users cannot.
I tried giving and enabling all permissions under visibility, design time and runtime at wsdbprod01136-AnalyticsServer_TrainingThing Thing but my users are still unable to access the object at legacy composer and show loading forever. I had an issue previously for creating value stream but worked after I change the permission. Please help with this issue.
Hi @hujingrui,
Were you able to find a solution? if yes, kindly provide information about what solved the issue, this might help additional community members with same observed behavior.
If you still encounter the same behavior let me know, and I will assist in finding a solution.
Asia
I am not sure if this is the correct way but I was able to get permission access to my users by setting visibility to
on the new composer which I was not able to via the legacy composer(cannot edit system object). I am not sure why the legacy composer is behaving this way.
Did you get the change to view information available about User Setup access from PTC Help Center?
What ThingWorx Platform version are you using?
Are you able to provide information about the documentation guide you are using? can you provide a link or the name and version of the guide?
Kr.
Asia
Hi @hujingrui,
Asia
