How to stop Navigate using Default Odata Connector
pshashipreetham
As of now, Thingworx Navigate is using ptc-windchill-OData-connector. I need to use an xyz-windchill-OData-connector by the Thingworx Navigate as the default; how can it be done? what changes need to be made to achieve this?
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
So, building blocks were introduced in 9.5.0. Since then, due to the Access Modifiers concept, most of the services can't be used, So a whole new project needs to be created or duplicated with existing ones and assigned to another project and re-create the entire structure step by step, which includes creation and configuration of the Odata Connector too.
There is no other way or workaround at this time.
Shashi Preetham,
2 REPLIES 2
Shashi Preetham,
