Hi, if I purchase a 50 users license, can I reuse any of this 50 users in case someone leaves the company or if I want to provide access to someone different?
Yes. The Admin(s) of an Org within Chalk can delete and invite users as needed through the Chalk Admin Center. If you have all 50 seats filled and then you delete a user from the Admin Center, you will then be able to invite a new user.
