Hi team,
we captured the procedure and 2 locations with Hololens.
Unfortunately I cannot add the locations to any step in the Editor. What was the issue? How to resolve it?
hi @oparfon,
You'll need to use the 'insert steps' option to add the capture to your procedure. Once you've done this, you should see the locations listed as an option for each step.
