Cannot add location to step
oparfon
Hi team,
 we captured the procedure and 2 locations with Hololens.
Unfortunately I cannot add the locations to any step in the Editor. What was the issue? How to resolve it?
1 REPLY 1
tmccombie
(To:oparfon)
hi @oparfon,
You'll need to use the 'insert steps' option to add the capture to your procedure. Once you've done this, you should see the locations listed as an option for each step.
