Conditional Routing in the procedures
oparfon
Good day Community,
 I am wondering if you know something about the condition based procedure flow  for the VEC. Is something like this on the roadmap?
For example:
 if the step instruction  said
“step 10: If any of the 3 sensors is dirty, go to step 15”
Step 11: Move to next check location
Step 14 : do A and B and  C and hen skip to step 16
Step 15:  follow these cleaning steps … first XXXXX, then YYYY etc .. finally ”
Step 16 : proceed normally
So that after step 10 we are going directly to step 15
A lot of customers asking about this capability?  What is your ideas regarding it?
Best Regards
Olena
tmccombie
(To:oparfon)
Hi @oparfon
You can navigate to any step needed in Vantage by going to the Step List. The Step list is available in the upper left corner:
Once in the step list - users can choose to view any step in the procedure:
This would require the user to manually navigate to that step.
tmccombie
(To:oparfon)
Hi @oparfon
mkron
(To:oparfon)
Olena,
We did this similar to the way tmccombie recommended.
We had a step that was solely for routing.
So it would the operator would following the step (say step 😎 to determine if any of the sensors were dirty.
Then the next step would say
"If any of the 3 sensors is dirty, continue to the next step.
If they are all clean, go to step 11"
If would be great if there could be some software/application routing, we would use that all the time.
