App: Vuforia Vantage
Software Version: 3.13.0
Device: iPhone and iPad
OS: iOS 17
Hello, I'm having some trouble while doing the Step Check training, everything works fine while going through the "Pass" state, but when I want to train the procedure with the "Fail" state the app displays the message "Tracking is unreliable", I used different devices to ensure it was not a hardware issue.
The procedure is for a part that is 2 meters long and has 80 step checks.
Thank you!
I think that your text alone does not provide sufficient insight into the problem to offer tips or suggestions for improvement for you.
