Anyone with Hololens experienced this?
I tried to publish a 3D model with 2D Image (.jpg) in a 3DImage widget.
During Preview, i can see the 2D Image.
But when I publish it, i can't see the 2D Image at all.
Attached is the sample image when previewed.
But when viewed in the actual hololens, the 2D image is nowehere to be seen.
Is there a special js code for this one?
Hello @Adrian_G. ,
tested your project on HoloLens 2 device but so far it was working OK.
when clicking on the checkbox it displayed the 3dImage widget and the display was OK.
Whe it not work in your project - there is possibly something based on other reasons and is not a problem of the 3DImage or file format
I think the following points could be checked there:
you can create a new project having only one space target and 3DWidget and check if in this minimal project the issue still occurs.
Regarding to the project implementation I have some remarks so that we make it more efficient:
$scope.belt=function()
$scope.view.wdg['model-1']['src'] = 'app/resources/Uploaded/Belt_Low.pvz';
$scope.view.wdg['3DImage-1']['src'] = 'app/resources/Uploaded/Slide21.JPG';
$scope.$applyAsync();
or better to use the setWidgetProp api:
$scope.setWidgetProp('model-1', 'src', 'app/resources/Uploaded/Belt_Low.pvz')
$scope.setWidgetProp('3DImage-1', 'src', 'app/resources/Uploaded/Slide21.JPG');
Hi @Adrian_G. ,
Is this picture what is attached the picture what you tried to used. I tested the issue for the HoloLens device with the current Studio /View app release / update this week and was not able to reproduce the problem on the Hololens. Tested the picture on both widgets – 3DImage button and 3DImage widget:
Possibly this is not the correct image file? In this case could you provide an sample image file where the issue is reproducible? Thanks
Possible reason could be the format: color settings, size (large number of pixels or large file size) . The attached file seems not to have an issue when I tested it.
Hi @RolandRaytchev .
Nope that is not the file I used where problem occured.
This file was produded from Powerpoint.
Is there an image requirement to be used for 3D Image?
I tried to use the same image for Mobile/Smartphone Version and it works fine.
But for 3D wear, i can't get the image to show up.
Hi @Adrian_G. ,
I tested in Studio the attached file (Slide1.JPG) in preview mode and on my HoloLens 2 device .Both was working fine
The picture worked for 3DImage and 3Dbutton.
Because the picture was to large I scaled it by factor of 0.3. The resolution is low and possibly when it is displayed as large picture it could cause a problem.
Checked what of restriction are known for HL device
https://docs.microsoft.com/en-us/dynamics365/mixed-reality/guides/pc-app-supported-file-formats
In the link above are mentioned the supported formats and possible file size limit.
-supported files Images PNG, JPG, JPEG, BMP, TIF
- here one of the restriction is 128 MB for file format
https://docs.microsoft.com/en-us/hololens/holographic-3d-viewer-beta
Here we can find the following info
File size
Minimum 5 KB
Maximum 500 MB
Textures
Texture maps must be embedded in the FBX file
Supported image formats
JPEG and PNG images
BMP images (24-bit RGB true-color)
TGA images (24-bit RGB and 32-bit RGBQ true-color)
Maximum texture resolution of 2048x2048
Maximum of one diffuse map, one normal map, and one reflection cube map per mesh
Alpha channel in diffuse textures causes pixels to be discarded if below 50%
So actually , no of the mentioned restriction above are relevant for your file. But as already mentioned I could not reproduce an issue with it. Possibly it will be converted automatically by OS system.
Hi @RolandRaytchev ,
Thanks for the reply.
Yes, i think the image file is within the limit. But i dont understand why i cant see in on my end.
Can you check this sample file of mine?
Can you see the 3D images? Let me know if we have the same problem.
Looking forward to your reply.
Hello @Adrian_G. ,
Here I want to provide an sample project , demonstrating how to highlight model Items in one Tops assembly via modelItem widgets and java Script . This demonstrates only one possible solution. I hope it could be helpful in your case.
@RolandRaytchev
Thank you very much.
My Vuforia View app was up to date.
Then when I checked OS, if im not mistaken there were 3 or 4 updates that are pending.
When I updated my Hololens OS, and tried to use view again, it worked!
And also thank you for the tip regarding the usage of modelItem, i tried it before but i dont know how can i solve a problem for example, i need to highlight a specific component, i need atleast 4 or 5 model items to completely change the property (color) of a specific part i want.
Example: I want to change the color of the muffler, when i use model item, the muffler has 4 or 5 parts and only one part can be called.
[is my explanation understandable? hehe]
Anyway regarding 3D image problem, thank you very much.
Hi @Adrian_G. ,
thanks for your feedback! I see that there is an additional issue what need to be checked more detailed.
First I want to refer to the following very helpful user guide which is a part of the Vuforia Studio Help:
and especially
Please, check if the techniques described in the mentioned links could be helpful in your case and , please, let me know if there are questions.
To the highlight of models . I am not sure So hope if I understood your quesiton correctly you want to change the appearance of a sub assembly e.g. muffler
IN your model the subassembly has the path : and the mean part Id path /occurrence /0/0/1/1/3/0/1/0/56 and for the whole subassembly muffler it is /0/0/1/1/3/0/1/0
So possible option is to :
Now, I added here a sample project for the HoloLens where we can see that I used 2 different properties file - as json in the upload directory. So when I click the one button it call config 1 - saved in properties.json and when I click the second test button it call the second properties configuration saved in properties1.json.
So I hope this will help. If not then please, let me know. Thanks
@RolandRaytchev
Sorry for the late reply.
Thanks for the comments.
I checked your links and I think its very informative.
As of now, I'll stick with my first method first since i have a deadline to finish.
When i have enough time i'll try to apply new methods that can make this project easier.
