Background color is set to white but it's black on android device
BS_9805643
2-Explorer
I need to have a white transparent background on a panel widget.
background-color: rgba(255,255,255,0.85);
The is the css code I'm using on the panel widget. When I test in preview everything looks fine, I test on iOS everything looks fine but on Android the background is black.
I tried to see if other colors would work and they do. I can set it to any other color but not white.
This is everything I've tried and it didn't work
background-color: rgb(255,255,255);
background-color: white;
background: white;
background: #FFFFFF;
 I had defined height of the panel and removed it in case it could be causing this problem, it wasn't.
1 REPLY 1
It might be overwritten by another CSS.
That's append when using a CSS stylesheet like this :
background-color: rgba(255,255,255,0.85)!important;
By the way when looking the screenshot attached in this thread, we can see a white background but not transparent!
If the issue is the transparency, it might be due to a limitation of web browser used in Vuforia View in Android.
Normally, it should be Google Chrome and it is compatible with RGBA colors.
More details here :
https://css-tricks.com/rgba-browser-support/
Best regards,
Samuel
