I was trying to call a function setModel(); with by using Application Events with voice Commands.
First thing I tried was simply calling the function:
setModel("schwader_aufgeklappt_Low.pvz");
But that seemed not to be working, after a bit of searching here, I found a post here that said, that I have to use viewCtrl. before that
viewCtrl.setModel("schwader_aufgeklappt_Low.pvz");
So I gave that a try. In preview it is now working, but isn't working on the HoloLens itself.
Does anyone have clue why that is and how to fix it?
try this
app.setModel("schwader_aufgeklappt_Low.pvz");
whitelist in View.js declare function using
$scope.app.setModel = function(val){
$scope.view.wdg['model-1'].src=...
try this
