Can RealWear HMT-1, HMT-1Z1 supports Vuforia Engine
thrinath
11-Garnet
Can RealWear HMT-1, HMT-1Z1 supports Vuforia Engine for 3D assembly instruction and Step check through Real wear by using Model Targets.
PG_10144204
(To:thrinath)
Hi @thrinath ,
RealWear HMT-1, HMT-1Z1, Supported features: ImageTargets, CylinderTarget, Multi Targets, VuMark. Extended Tracking not supported (no Device Tracking).
Model Targets require advanced device tracking capabilities, which are typically supported by devices like HoloLens 2 or ARCore/ARKit-enabled devices.
Alternative Solutions, If you need to use Model Targets for 3D assembly instructions:
Use compatible devices like HoloLens 2, Magic Leap 2, or ARCore/ARKit-enabled smartphones/tablets for full Model Target functionality.
2 REPLIES 2
VladimirN
(To:thrinath)
PG_10144204
(To:thrinath)
Hi @thrinath ,
