ASUS N76VB
Windows 7 Ultimate x64
Memory = 8GB DDR3
NvideoGeForce 740
I download setup.exe from https://studio.thingworx.com/home/
I cannot install this application on my ASUS with the following reports:
[09/03/2017 02:45:34] Studio Version 8.0.3 (8.0.3.1898)
[09/03/2017 02:45:34] Status Message: Version 8.0.3 (8.0.3.1898)
[09/03/2017 02:45:34] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[09/03/2017 02:45:35] Starting node.exe
[09/03/2017 02:45:37] module.js:471
[09/03/2017 02:45:37] throw err;
[09/03/2017 02:45:37] ^
[09/03/2017 02:45:37] Error: Cannot find module 'debug'
[09/03/2017 02:45:37] at Function.Module._resolveFilename (module.js:469:15)
[09/03/2017 02:45:37] at Function.Module._load (module.js:417:25)
[09/03/2017 02:45:37] at Module.require (module.js:497:17)
[09/03/2017 02:45:37] at require (internal/module.js:20:19)
[09/03/2017 02:45:37] at Object.<anonymous> (C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\utils\logging.js:19:15)
[09/03/2017 02:45:37] at Module._compile (module.js:570:32)
[09/03/2017 02:45:37] at Object.Module._extensions..js (module.js:579:10)
[09/03/2017 02:45:37] at Module.load (module.js:487:32)
[09/03/2017 02:45:37] at tryModuleLoad (module.js:446:12)
[09/03/2017 02:45:37] at Function.Module._load (module.js:438:3)
Before it I used 8.0.2 on this ASUS.
But now cannot install 8.0.3 on it.
I did it several times during three days with the same result.
How can I really install this upgrade on my notebook?
Thank you in advance.
Vladimir Krayushkin : Could you please confirm if you are having Node.js installed externally on your machine . There is a know issue when Studio installer gets break if Node.js is installed externally.
Also, could you please try deleting the folder ThingworxStudio insdie directory C:\Users\Admin002\AppData\Roaming and then try installing again.
-Durgesh
-Durgesh
Hello Durgesh!
Thanks for your message.
I check the file system: no, I didn't install node.js separate or externally.
And during last attempts to install 8.0.3.1898 I deleted all directories/files from C:\Users\Admin002\AppData\Roaming (and last case - the ThingworxStudio directory from C:\Users\Admin002\MyDocument too).
But even after that I see the same installation message:
- Studio Version 8.0.3 (8.0.3.1898)
- Status Message: Version 8.0.3 (8.0.3.1898)
- Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
- Starting node.exe
- module.js:471
- throw err;
- Error: Cannot find module 'debug'
- at Function.Module._resolveFilename (module.js:469:15)
- at Function.Module._load (module.js:417:25)
- at Module.require (module.js:497:17)
- at require (internal/module.js:20:19)
- at Object.<anonymous> (C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studiodownload.vuforia.io\dist\server\utils\logging.js:19:15)
- at Module._compile (module.js:570:32)
- at Object.Module._extensions..js (module.js:579:10)
- at Module.load (module.js:487:32)
- at tryModuleLoad (module.js:446:12)
- at Function.Module._load (module.js:438:3)
Any idea?
BTW: I find log file from another laptop with successful modification of ThingWorxStudio 8.0.2 to 8.0.3. The beginning of log for first-time 8.0.3 Studio running is the following:
[09/01/2017 13:48:48] Studio Version 8.0.3 (8.0.3.1898)
[09/01/2017 13:48:48] Status Message: Version 8.0.3 (8.0.3.1898)
[09/01/2017 13:48:48] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[09/01/2017 13:48:49] Status Message: Performing First Time Setup (Application)...
[09/01/2017 13:48:49] Removing C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist
[09/01/2017 13:48:50] Unzipping mbdist.zip to C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[09/01/2017 13:48:53] Status Message: Performing First Time Setup (Libraries)...
[09/01/2017 13:48:53] Removing C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules
[09/01/2017 13:49:37] Unzipping mbmodules.zip to C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[09/01/2017 13:50:22] Starting node.exe
[09/01/2017 13:50:23] debug: [twx-studio:logging] Debug logging enabled. DEBUG=twx-studio*,ar-extension*,ves-publish*
[09/01/2017 13:50:23] Fri, 01 Sep 2017 09:50:23 GMT twx-studio:logging DEBUG_FD=1 so the "debug" module will log to stdout instead of stderr
[09/01/2017 13:50:24] info: [twx-studio:initializer] Node version: 6.10.0
[09/01/2017 13:50:24] info: [twx-studio:initializer] ThingWorxStudio launched with the following arguments: _=[C:\Users\Admin002\Documents], $0=..\..\..\..\..\..\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\index.js
[09/01/2017 13:50:24] info: [twx-studio:initializer] ThingWorxStudio dir: C:\Users\Admin002\Documents\ThingWorxStudio , home dir: C:\Users\Admin002\Documents
[09/01/2017 13:50:24] debug: [twx-studio:initializer] Projects dir: C:\Users\Admin002\Documents\ThingWorxStudio\Projects
[09/01/2017 13:50:24] debug: [twx-studio:initializer] Extensions dir: C:\Users\Admin002\Documents\ThingWorxStudio\Extensions
[09/01/2017 13:50:24] debug: [twx-studio:initializer] ThingMarks dir: C:\Users\Admin002\Documents\ThingWorxStudio\ThingMarks
[09/01/2017 13:50:24] debug: [twx-studio:initializer] Move /VuforiaStudioEnterpriseExtensions
[09/01/2017 13:50:24] debug: [twx-studio:fileUtils] C:\Users\Admin002\Documents\VuforiaStudioEnterpriseExtensions does not need to be moved, it does not exist
[09/01/2017 13:50:24] debug: [twx-studio:initializer] Move the projects dir
[09/01/2017 13:50:24] debug: [twx-studio:fileUtils] C:\Users\Admin002\Documents\VuforiaStudioEnterpriseProjects does not need to be moved, it does not exist
[09/01/2017 13:50:24] debug: [twx-studio:initializer] Initialize builderSettings
[09/01/2017 13:50:24] debug: [twx-studio:index] Done with initialization
[09/01/2017 13:50:24] debug: [twx-studio:index] Startup process.argv is ["C:\\Users\\Admin002\\AppData\\Local\\Apps\\2.0\\AY7BLW01.T25\\PMEMTDO5.R44\\thin..udio_cd45769e4d993f77_0008.0000_6e3e378186bc2036\\node.exe","C:\\Users\\Admin002\\AppData\\Roaming\\ThingworxStudio\\studio-download.vuforia.io\\dist\\server\\index.js","C:\\Users\\Admin002\\Documents"]
[09/01/2017 13:50:25] debug: [twx-studio:extension-manager] extensionName to require ves-ar-extension
[09/01/2017 13:50:25] ar-extension version 8.0.3 (1.16.633)
[09/01/2017 13:50:25] debug: [twx-studio:extension-manager] extensionName to require ves-basic-web-widgets-extension
[09/01/2017 13:50:25] debug: [twx-studio:extension-manager] extensionName to require ves-sample-projects
[09/01/2017 13:50:25] debug: [twx-studio:extension-manager] extensionName to require twx-data-provider
[09/01/2017 13:50:25] debug: [twx-studio:projectHelper] []
[09/01/2017 13:50:25] Status Message: Version 8.0.3 (8.0.3.1898)
[09/01/2017 13:50:25] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[09/01/2017 13:50:27] debug: [twx-studio:importProject] StudioSample3DImport already exists
[09/01/2017 13:50:27] debug: [twx-studio:importProject] StudioSampleEyewear already exists
[09/01/2017 13:50:27] debug: [twx-studio:importProject] StudioSampleQuadcopter already exists
[09/01/2017 13:50:27] debug: [twx-studio:importProject] Done copying sample projects
[09/01/2017 13:50:38] debug: [twx-studio:sockets] a user connected 0w9jK6j3uyEa1qu9AAAA
[09/01/2017 13:50:39] [0mGET /%7B%7B::projectType.imgPath%7D%7D [32m200 [0m10.174 ms - 2201 [0m
[09/01/2017 13:50:39] [0mGET /%7B%7B::view.imgPath%7D%7D [32m200 [0m9.331 ms - 2201 [0m
[09/01/2017 13:50:39] [0mGET /%7B%7BviewType.imgPath%7D%7D [32m200 [0m9.077 ms - 2201 [0m
[09/01/2017 13:50:39] [0mGET /images/%7B%7B::w.name%7D%7D.png [32m200 [0m8.868 ms - 2201 [0m
[09/01/2017 13:50:39] debug: [twx-studio:sockets] EMIT builderSettings all
[09/01/2017 13:50:39] debug: [twx-studio:projectSettings] Skipping appDir "node_modules", no appConfig.json found
[09/01/2017 13:50:40] debug: [twx-studio:projectSettings] Skipping appDir "node_modules", no appConfig.json found
[09/01/2017 13:50:40] debug: [twx-studio:sockets] EMIT updateProjects 0w9jK6j3uyEa1qu9AAAA
[09/01/2017 13:51:01] debug: [twx-studio:upgradeProject] upgradeIfNeeded StudioSampleQuadcopter
[09/01/2017 13:51:01] Fri, 01 Sep 2017 09:51:01 GMT ar-extension:upgrade Upgrade needed. Current version 8.0.3 (1.16.633) , new version 8.0.1 (1.14.536)
[09/01/2017 13:51:01] debug: [twx-studio:sockets] EMIT UpgradeInProgress all
[09/01/2017 13:51:01] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Begin upgrade of project StudioSampleQuadcopter
[09/01/2017 13:51:01] info: [twx-studio:upgrade:StudioSampleQuadcopter] Upgrading project Studio Sample - Quadcopter C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter from 8.0.1 (1.14.536) to 8.0.3 (1.16.633)
[09/01/2017 13:51:01] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Make sure there are not any stale files lying around
[09/01/2017 13:51:01] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Removing C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter/css/
[09/01/2017 13:51:01] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Removing C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter/dist/
[09/01/2017 13:51:02] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Removing C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter/extensions/
[09/01/2017 13:51:02] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Removing C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter/preview3d/
[09/01/2017 13:51:02] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Removing C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter/src/phone/resources/Default/
[09/01/2017 13:51:02] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Removing C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter/theme/
[09/01/2017 13:51:02] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Copying /src/**/* to project, overwrite=false
[09/01/2017 13:51:02] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Copying /**/* to project, skip /src/**/*, overwrite=true
[09/01/2017 13:51:03] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Copy of project files complete
[09/01/2017 13:51:03] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Updating version to 8.0.3 (1.16.633)
[09/01/2017 13:51:03] debug: [twx-studio:upgrade:StudioSampleQuadcopter] onupgrade sucessful, now build the project
[09/01/2017 13:51:03] debug: [twx-studio:upgrade:StudioSampleQuadcopter] BEGIN buildApp StudioSampleQuadcopter_1504259463175
[09/01/2017 13:51:03] debug: [twx-studio:upgrade:StudioSampleQuadcopter] write settings
[09/01/2017 13:51:03] debug: [twx-studio:projectSettings] write project settings StudioSampleQuadcopter
[09/01/2017 13:51:03] debug: [twx-studio:upgrade:StudioSampleQuadcopter] copy runtime extensions
[09/01/2017 13:51:03] debug: [twx-studio:upgrade:StudioSampleQuadcopter] packageThemeSet
[09/01/2017 13:51:03] debug: [twx-studio:themeManager] generating studio-designtime-vars.scss
[09/01/2017 13:51:03] debug: [twx-studio:themeManager] generating studio-runtime-vars.scss
[09/01/2017 13:51:03] debug: [twx-studio:themeManager] processThemes
[09/01/2017 13:51:03] debug: [twx-studio:themeManager] Making theme: twx-light , includePaths: C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\ves-ar-extension\src\src-scaffold\ionic\scss
[09/01/2017 13:51:03] debug: [twx-studio:themeManager] Building twx-light-theme-designtime.css
[09/01/2017 13:51:03] debug: [twx-studio:themeManager] Making theme: twx-dark , includePaths: C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\ves-ar-extension\src\src-scaffold\ionic\scss
[09/01/2017 13:51:03] debug: [twx-studio:themeManager] Building twx-dark-theme-designtime.css
[09/01/2017 13:51:04] debug: [twx-studio:themeManager] Building twx-dark-theme.css
[09/01/2017 13:51:04] debug: [twx-studio:themeManager] Building twx-light-theme.css
[09/01/2017 13:51:05] debug: [twx-studio:themeManager] building system-widget-extensions-designtime.css
[09/01/2017 13:51:05] debug: [twx-studio:themeManager] building app-designtime.css
[09/01/2017 13:51:05] debug: [twx-studio:themeManager] building system-widget-extensions.css
[09/01/2017 13:51:05] debug: [twx-studio:themeManager] building app.css
[09/01/2017 13:51:05] debug: [twx-studio:themeManager] copying css files for selected theme twx-light
[09/01/2017 13:51:05] debug: [twx-studio:upgrade:StudioSampleQuadcopter] onBuild
[09/01/2017 13:51:05] info: [twx-studio:upgrade:StudioSampleQuadcopter] Building ves-ar-extension app: Studio Sample - Quadcopter
[09/01/2017 13:51:05] Fri, 01 Sep 2017 09:51:05 GMT ar-extension:gulp-shared clean
[09/01/2017 13:51:05] debug: [twx-studio:upgrade:StudioSampleQuadcopter] pathDir C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter
[09/01/2017 13:51:05] debug: [twx-studio:upgrade:StudioSampleQuadcopter] scaffoldDir C:\Users\Admin002\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\ves-ar-extension\src\src-scaffold
[09/01/2017 13:51:05] debug: [twx-studio:upgrade:StudioSampleQuadcopter] copySrc
[09/01/2017 13:51:05] Fri, 01 Sep 2017 09:51:05 GMT ar-extension:gulp-shared copySrc
[09/01/2017 13:51:10] debug: [twx-studio:upgrade:StudioSampleQuadcopter] buildApp
[09/01/2017 13:51:10] Fri, 01 Sep 2017 09:51:10 GMT ar-extension:gulp-shared build
[09/01/2017 13:51:10] Fri, 01 Sep 2017 09:51:10 GMT ar-extension:gulp-shared compile view contents Home
[09/01/2017 13:51:10] Fri, 01 Sep 2017 09:51:10 GMT ar-extension:gulp-shared Extract pvi from src pvz zip C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter\src\phone\resources\Uploaded\ptc-quadcopter-animated.pvz C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter\dist\phone\app\resources\Uploaded\ptc-quadcopter-animated\l-Creo 3D - ReplaceBattery.pvi
[09/01/2017 13:51:10] Fri, 01 Sep 2017 09:51:10 GMT ar-extension:gulp-shared compile view contents Choice
[09/01/2017 13:51:10] Fri, 01 Sep 2017 09:51:10 GMT ar-extension:gulp-shared Working with view named C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter\dist\phone\app\components\Home.html which exists? [true]
[09/01/2017 13:51:10] Fri, 01 Sep 2017 09:51:10 GMT ar-extension:gulp-shared Working with view named C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter\dist\phone\app\components\Choice.html which exists? [true]
[09/01/2017 13:51:10] debug: [twx-studio:upgrade:StudioSampleQuadcopter] END buildApp StudioSampleQuadcopter_1504259463175
[09/01/2017 13:51:10] debug: [twx-studio:upgrade:StudioSampleQuadcopter] Build succeeded.
[09/01/2017 13:51:10] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\Admin002\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter\upgrade.log
[09/01/2017 13:51:10] debug: [twx-studio:sockets] EMIT getProjectDefinition 0w9jK6j3uyEa1qu9AAAA
[09/01/2017 13:51:11] error: [twx-studio:index] Respond with 404 ENOENT: no such file or directory, stat 'C:\Users\Admin002\Documents\ThingWorxStudio\Projects\{{$root.currentProject.fileName}}\src\phone\guidance\images\Illustration_0thingmark.svg'
and in this case ThingWorx Studio installed and run well: I could move my own "old" projects here and can start here new projects.
I try compare log from my bad case and that good case, I compare them from the beginning message to "Start node.js" message and find the difference :
"My bad and error installation":
- Starting node.exe
otherwise, in good case I have the following:
Starting node.exe
I underscored logs in the successful case addressing the steps (before start node.js) which cannot perform in the bad case. - What does it mean? Why I cannot install Applications and Libraries at all? May be it is a reason.?
OK, Durgesh, You are right, the reason - "old" node.js scripts before installation of the new TWxStudio release:
I remove of node.js yet another time:
1. I uninstall ThingWorx Studio from my Windows 7 Ultimane x64 laptop.
2. I delete all "node.js" files from "... AppData/Roaming/" of actual User (Admin002 in my private case)
2.a I remeber I installed 8.0.2 for other users on the same laptop configuration several weeks ago. I didn't uninstall them before. Now I uninstall all installed TWxStudio for others and node.js" files of them.
3. Then - Restart Windows and network, start "setup.exe" (but in my case I make it by ThingworxMobileBuilderApp.application), and my ThingWorx Studio 8.0.3.1898 are running now:
Thanks for help, Durgesh! ! !
-Vladimir.
Vladimir Krayushkin : Glad that the issue got resolved and you are back in action again
-Durgesh
