Deleting an Unloadable Experience in the Library in Vuforia View
Hi all,
I hope like to do a clean up of my experience server.
While i am using the Vuforia View in Mobile/IPAD, i notice a list of project in the library, but it is not loadable.
I check the directory of the experience server.: \ptc\studio-es-store\projects, i am not able to find the related project related to the name of the experience in the library.
1. I read Article - CS281363, and would like to try curl, i hope to clarify the following: " Project title might not be the same title of the publish experience." when i using the command below.
-X "DELETE" https://<your-domain_name>/ExperienceService/content/projects/<projectname>
How can i identify the correct "projectname" to delete, as i cannot find the "project" folder.
2. Can i view the from the folder in the directory, what title is used for the Title for the experience?
3. If i have the project in the ES, but i am not able to open the project with the Vuforia Studio, as i am not the developer, can i delete the project, so it will be deleted in the list in the library of Vuforia View too?
I am not sure if i am reading the correct article, i just hope to clean up the experience server, and remove unwanted experience. Is there any "back door"?
Awaiting for your advice!! Thank you for sharing your experience.
Best regards
newbie Kek
