Does the studio emit or broadcast any event when the sequence is finished? (Hololens)
Yakun
3-Newcomer
Hi lads,
I'm trying to create a set of buttons according to the states of sequential animation.
Now I can get the initial state by setting the initial value or resetting the sequence, while I can also get the "NewStep" state by listening to the "NewStep" event. But I can't find a way to capture the "finish" state. Is there an event emitted or broadcasted after finishing the sequence?
Any help would be appreciated.
I think you can use the 'Play stoped' event in combination with the $scope.$on('newStep', function(evt,arg) {... event.
I tested the play stoped event and have the follow behavior:
-Now I tested the model. play  service:
and had one start and one stop event (printing of the console.warn() funciton)
When I tested then play all I had:
so my observations here  are that it started for each step a "play started" event and only on finish of the sequence called the "play stoped" event.  Here I started play All from the step 3.
So means the solution could be to check the current step and depending on it - if it is the last (number) step - in this case we can interpret the finish event as finish of the sequence.
2 REPLIES 2
Thank you, it's working perfectly in this way.
