Error when starting Vuforia Studio
  • August 1, 2018
  • 5693 views
I have a problem with starting my Vuforia Studio 30 day-trial version. Itยดs downloaded, installed, everything okay. When try to start the application, it gives back an error.
It says I should check the protocol, which I attached to this post.
Error Message and the protocol are attached.
I have no idea how to fix this, I would really appreciate some help!
Thank you!
Hi @cs316,
I have observed the below error in the screenshot:
error: [twx-studio:index] uncaughtException { Error: listen EADDRINUSE 127.0.0.1:3000
Could you please verify if another process is running on port 3000 and kill/move that process if blocked.
Please restart  Vuforia Studio and open the application again after the above modification.
cs3161-VisitorAuthor
Hi @ytella,
thanks for the fast reply!!
How can I check if another process is running on port 3000?
I remember that an old trial version worked on this port, but actually I deleted every PTC-Application before installing the new trial version...
Thank you!
Okay, thanks.
I checked all ports (see attachement), but no process is running on exactly port 3000.
Is there anything else I can check? Or any other possibility to get this software running?
Chris
