Federation Error
Giuseppe_Fiore
Federation Error
I have created a federation between a Thingworx Core (customer)  & Instance Thingworx Vuforia (customer) , to connect some services on a thing into AR experience.
But not function , and into monitor Web i have this type of Message:
Refilling connections on [endpoint 477, uri: wss://xxxxxxxxxxxxxxxxxxx:443/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
i have tried to connect the same Federation with a trial instance of Vuforia & this work perfectly.
Should something be activated in the Vuforia instance (customer) ? or what ?
thnx
Giuseppe
if you follow the instructions form "TWX Federation Setup Guide.docx" is the federation working in Vuforia Thingworx instance- means step 5 is working there?
So means is the problem in the federation on the Vuforia Thingworx instance or  the issue occurs only in Vuforia Studio?
