Can I add my own font file (* .TTF) as a resource for "Vuforia Studio" instead of an external font?
Can I use the resource font I have added?
Or is it possible to use only external fonts via unconditional URL like below?
@import url (// fonts.googleapis.com/css?family=Bowlby One);
.specialfont {
font-family: 'Bowlby One';
Warm Regards,
SeonHo
Hello CHASEONHO
Maybe this will help. I prefer to store different fonts in Resources\Fonts folder:
/// Creating a new font style:
@font-face {
font-family: digital;
src: url('#{$resources}/Fonts/DIGITALDREAM.ttf');
/// Using the new font style:
.digital {
Regards
Tomas
@CHASEONHO Custom CSS can be added easily in the application CSS section, if you also have custom files to add to the project with the font definitions, you can upload them via the resources upload action and then reference them from the CSS file.
Adding fonts to the CSS file via CSS import should work, and one can also add fonts via javascript in the home.js file by creating the link tag with the URL to the font.
I think the 3d label widget can use the CSS fonts if they exist already in the page. See some examples about how to import fonts such from this post:
https://stackoverflow.com/questions/14676613/how-to-import-google-web-font-in-css-file
@import url('https://fonts.googleapis.com/css?family=Open+Sans')
-Durgesh
Hello CHASEONHO
@font-face {
.digital {
Regards
Tomas
Thank you for answer.
That's correct!
Is there a way to add as a default resource without adding fonts to every project?
Just a note that I was seeing an issue with local custom fonts on iOS a few months back. Not sure if this has been resolved.
https://community.ptc.com/t5/Studio/Custom-Fonts-not-working-on-iOS/m-p/609780
