Jun 3, 2019 1:10 PM UTC
How to change resource of 3D image with JS code?
I would like to change resource of 3D image with JS code to avoid inserting all pictures. Can anyone help me?
Janos
18-Opal
Jun 3, 2019 8:10 PM UTC
Just set the "src" property of the 3D image widget to the graphic you want. You'll need to include the relative path, usually "app/resources/Uploaded/{image filename}". Here's an example:
$scope.changePic = function() {
//use this form for the stock images //$scope.setWidgetProp("3DImage-1","src","app/resources/Default/vu_seq_pause.svg");
// use this form for your own uploaded images $scope.setWidgetProp("3DImage-1","src","app/resources/Uploaded/myimage.png"); }
18-Opal
Jun 3, 2019 8:11 PM UTC
You can define the 3D image source in JS like this:
$scope.view.wdg["3DImage-1"]['src'] = 'app/resources/Uploaded/<image you want to set>';
