I am using the trail version to explore the Vuforia Studio to develop the 2D experience and after installation, I could not able to see the Default Experience Service URL.
Could you please let me know the steps to generate the Default Experience Service URL?
I have attached the screen shot for your reference.
Thank You!
@Jayachandra You can do auto-configuration for setting/getting your Trail Studio Experience Service. Open Studio application- http://localhost:3000 and then click right click 3 dots (...) -> Portal Login -> Enter your PTC account credentials and click configure.
Upon successful auto-configuration, you should see the Default ES been configured within Studio application.
-Durgesh
Hello Durgesh,
I have tried the same steps you have mentioned. I am getting the "Auto configure failed. Check log for errors." Could you please suggest me.
I have attached screenshot and logs as well for your reference.
Thank You!
@Jayachandra Could you please verify that below 2 URL is not getting blocked and share output when you open them in the browser.
https://studio-download.vuforia.io/
https://trial.studio.vuforia.com/api/v1
-Durgesh
When I am trying the URL's which you provided, it was asking for login credentials and after I provided those also I am unable to login.
@Jayachandra Please share the user ID been used to start Studio Trial and share a snapshot of trial portal post-login -https://trial.studio.vuforia.com/
Durgesh
@Jayachandra In case you still having the issue then request to please share the user ID been used to start Studio Trial and share a snapshot of trial portal post-login -https://trial.studio.vuforia.com/
