7-Bedrock
May 13, 2021 7:53 AM UTC
How to include a .json file from Vuforia Studio resources
Hi all,
I have a .json file  that I will call from home.js script.
I uploaded the .json file into the Vuforia resources: how can I include this .json file, so that I can access it?
I've tried many functions described in similar topics (here or here ) and functions I found browsing the internet ($scope.getJSON('...'), $scope.loadJSON('...')...) but none of them worked.
Best regards,
Stefano
May 14, 2021 6:49 AM UTC
Hi @stefano,
here a simple example  which shows how to load a json file form resource/Upload project folder and saved it to a global/$scope variable:
//Global Variables
var pjson ="motordata.json";
//JSON File Name with extension
$scope.jsonData={}; //global $scope variable where the received json file is saved
gotJSON=function(data){
    try{
        $scope.jsonData=JSON.parse(data);
 console.warn(  JSON.stringify($scope.jsonData))
catch(wrong){    console.warn(wrong);}
doRead=function (jsonFile){
fetch(jsonFile)
  .then(response=>response.text())
  .then(data=>gotJSON(data))
$scope.Init=function() {
doRead('app/resources/Uploaded/'+pjson);
//read the json file form the resources/Upload Vuforia Studio Project folder
// ... do here other init stuff
$scope.$on('$ionicView.afterEnter', function() {
      console.info("started $ionicView.afterEnter  at time: "+Date(Date.now()))
  $scope.Init();
//execute the init function when the view was loaded
In the example above I used the fetch method but also $http service could be used: example:
 $http.get('app/resources/Uploaded/' + jsonFile).success(function(data, status, headers, config) {
    $scope.myJsonData=data;
// here you could work with myJsonData e.g.
  console.log(JSON.stringify($scope.myJsonData) // e.g. print it to console
  // depending on the content of the json file you can do some actions
   try {
      Object.keys($scope.myJsonData).forEach(function(item){
        console.log ("Text =" +$scope.myJsonData[item].Text);
        var labelID = $scope.myJsonData[item].LabelID;
        $scope.view.wdg[labelID].text = $scope.myJsonData[item].Text;
        $scope.view.wdg[labelID].visible = true;
        $scope.view.wdg[labelID].x = $scope.myJsonData[item].x;
        $scope.view.wdg[labelID].y = $scope.myJsonData[item].y;
        $scope.view.wdg[labelID].z = $scope.myJsonData[item].z;
        $scope.view.wdg[labelID].fontColor = $scope.myJsonData[item].status;
   } catch(ex) {
     console.log ("Possible Error: When trying to work through Grid data passed from IOT service there was an issue Exception:"+ex);
   // this example above work only for json array which contains ojects with key/ property pairs
   // Text: ... , x: .... , y: ... z: .... , LabelID : ...
Hi @stefano,
//Global Variables
    try{
fetch(jsonFile)
  $scope.Init();
   try {
   } catch(ex) {
