How can we make a button or any other widget such that when it is pressed it plays a particular sequence step only and gets the step descriptions as well
hi,
R u saying, it should show the action description..?? In that case go to properties of that widget(left side corner) as shown in figure I am showing it for button widget but you can see such property for most of the widgets.
After writing your description go and place your cursor on that button you will get the description.
BR,
madhu
No that is not what I am not looking for. when we bind a button with the model we only have option to play and play all the sequence Steps in succession. What am I looking for is that can we make it to play a particular step only when we press the button maybe by writing a script.
