I want to make the readings of a 3D Gauge decrease and stop at a certain value once a function has been triggered. Once the 3D gauge reading stops at that particular value, I want to change the resource image of the 3D Gauge to indicate an alert / caution.
Hello ES_9419715,
Sadly here, Enable State-Based Formatting will not help because image is not part of the properties manageable like that.
The behavior wanted seems like an animation.
So Javascript functions will need to use a timeout to let the end user to see the effect.
Please have a look to this thread about timeout function :
https://docs.angularjs.org/api/ng/service/$timeout
To change a resource of any 3D or 2D Widget, please have a look to this thread :
So, source code who be similar to like that :
$scope.ChangeIcon = function()
console.log ("ChangeIcon");
//$scope.setWidgetProp('3DGaugeExample', 'resource', "app/resources/Uploaded/Fichier_Stop_hand.svg");
$scope.view.wdg["3DGaugeExample"]['resource'] = 'app/resources/Uploaded/Fichier_Stop_hand.svg';
$scope.CheckChangeIcon = function(val)
// Low limit of value displayed in 3D Gauge
if (val <= 1)
// Change image of this 3D Gauge in 5 ms
$timeout($scope.ChangeIcon, 5);
$scope.DecreaseValue = function()
// Read current value of 3D Gauge. Start value is at 20.
var value = $scope.getWidgetProp('3DGaugeExample', 'text');
$scope.CheckChangeIcon (value);
if (value == 1)
return;
// Decrease value
value = value - 1;
// Apply the value
$scope.setWidgetProp('3DGaugeExample', 'text', value);
if (value > 1)
// Continue to decrease
$timeout($scope.DecreaseValue, 1);
$scope.Start = function()
// Decrease value of 1 in 1 ms later
Please find a sample Project.
It has one issue where I am blocking.
Image is not applied in 3D Gauge but Function is called as expected.
Some investigation is needed about this point.
Best regards,
Samuel
Hello ES_9419715,
if (val <= 1)
if (value == 1)
return;
// Decrease value
value = value - 1;
// Apply the value
if (value > 1)
Best regards,
Samuel
Hello @sdidier ,
nice project example. One thing we need to change there. The resource properie from UI is "src" in JavaScript so therefore we need to change the statement:
// please change it to
$scope.view.wdg["3DGaugeExample"]['src'] = 'app/resources/Uploaded/Fichier_Stop_hand.svg';
Thank you @sdidier! The code works for decreasing value of 3D Gauge and as you mentioned the image in the 3D Gauge source isn't changing. Thanks once again!
