Please share the document of uploading the extra Thingmarks to the experience server.
Thanks in advance.
@RolandRaytchev Thanks for your input on the article shared by @dupatel but there is one problem is that I don't want to lose my existing experiences present in my 3 default thingmarks.
What I found in JSON is that there is one option of "thingmarkDomain" which means all the extra thingmarks including the default ones are having the same value as per your screenshot.
I tried ur solution but the existing experiences got vanished which were present in 3 default thingmarks.
Could you pls let me know can we put more than one thingmarkDomain value so that we cannot lose any of our existing thingmark experiences with different thingmark domain.
@ranjank The default Thingmarks are associated with a particular thing mark domain and are provided with your Studio Trial account. However, since you already have setup On-premise ES so should update the existing ThingMarks and also should publish your existing projects to your own On-premise ES. Then there will be no need to keep old Thingmarks.
In case you still want to keep the old ThingMarks then should not update the new ThingMarks inside Studio application. You can continue using the on-premise new Thingmarks ID directly and scan the ThingMarks using an e-copy or printed version of Thingmarks.
Hello @ranjank ,
here is a feedback from dev team according to the option of "thingmarkDomain":
With other words you do not need to set or change this property and you can add manually thingmarks belonging to different domains in the json setup file ( ...Documents\VuforaStudio\builder-settings.json your local ) for yours Vuforia Studio installation)
