How to use button/image widget to select and play particular model from multiple models?
M_shah
I have multiple of models uploaded in studio 3D canvas and in 2D canvas i have particular button/image widget for particular model ...When i am pressing button that particular model will be visible and play the sequence and other models are hidden
1 REPLY 1
tmccombie
(To:M_shah)
You can bind the button click event to the 'play all' service for model you want to view. You can also call a JS function on the same click even to hide the other models from the canvas. For example, if I wanted to hide model-2 on the click event, I would add this code to my home.js file:
$scope.hideModel2 = function() {
  $scope.view.wdg['model-2']['visible']=false;
Then, on the click event, add 'hideModel2():'.
