For example, When a specific row in the data grid is selected, it would display a popup with labels that follow the rows items that was clicked on.
Hi @Jimmy4 ,
you can use the following options.
The one option is to use directly the Item click. You can define a code e.g.:
$scope.app.ItemClick=function() {
//console.warn($scope.view.wdg['dataGrid-1'])
$scope.$applyAsync();
console.warn("selected Name="+$scope.view.wdg['dataGrid-1'].data.current.Name)
console.warn("selected Value="+$scope.view.wdg['dataGrid-1'].data.current.val)
console.warn("selected DESC="+$scope.view.wdg['dataGrid-1'].data.current.Desc)
And then when we test it - we will have:
You can alternative use also another listener to handle the selected value in the dataGrid widget. But , please, pay attention that this another option is global and will work for many dataGrid widgets and alo it will deactivate the ItemClick. Means the ItemClick will work but the current selection is not updated. So that when you define the repeater listener the ItemClick will not be able to handle the current data Set:
twx.app.fn.clickItemInRepeater = function(item,list,isMultiSelect)
console.warn("called clickItemInRepeater()");
console.log("twx.app.fn.clickItemInRepeater item"); console.warn(item);
console.log("twx.app.fn.clickItemInRepeater list"); console.warn(list);
console.log("twx.app.fn.clickItemInRepeater isMultiSelect"); console.warn(isMultiSelect);
console.log("Item.name="+item.Name);
console.log("Item.val="+item.val);
console.log("Item.Desc="+item.Desc);
