I have a project finished that i want to publish, but when i go to do so, its asked for a localhost:3000 username and password.
Message was edited by: Sushant Pandey moved to ThingWorx Studio
Brad, Technically it is not wrt localhost credentials, the credentials should be of the corresponding Experience Service.
thank you for your reply, and if you have anymore ideas on how to publish for us here let us know, thank you
Just curious, did you enroll for TWX studio Trial program and received a welcome email? If so, you can make use of those credentials for publishing.
First go to Configuration -> Info. Enter and validate Experience Server url. Credendentials will same as that is used on ThingWorx Studio – Unleash your imagination.
Then go to Configuration -> Experiences. Make sure your ThingMark Id is entered.
Click on Publish.
If you face any issue please share the error screenshot and ThingWorx Studio logs.
