Information required on Labelling in Published projects
bwhelan
Just wondering if anyone can assist?
I have recently began to participate in the pilot and have published a few small models as projects. I have successfully managed to use Sequenced steps created in Illustrate in some published projects.
My question is although I have added simple annotations to the Sequences created in Illustrate, these notes do not appear in the published project in Viewer. If it is a thing that this function cannot happen, is there an easy way to attach some simple notes to be displayed in Viewer, possibly through the 2D canvas, which change with each sequence step? Perhaps a specific tutorial?
Thanks for any help,
Brian
tmccombie
(To:bwhelan)
Hi Brian. Not sure if you've found this Community post yet: Display sequence step names from Creo Illustrate It may be helpful.
mwassmann
(To:bwhelan)
Additionally to what Tara wrote you can add /and/or/ modify the step information that is coming in.
so to say by saying "if currentstep is 1, do this and that" .
Martin
