Is it possible to set a default value for choosing a sequence animation during runtime?
Hello everyone,
based on Can't use more than one sequence animation in a single experience in ThingWorx studio. I implemented the second solution. When I load the application, there is an empty value set (no animation sequence is selected). I have to choose an animation sequence first. Is it possible to define a default value, e.g. in this case a default sequence which is automatically chosen from the beginning?
Thank you!
