I have 2 issues.
1. The model has two sequences ( Figure 1 & Figure 2 ). I leave the sequence options under model props empty so that I can set the sequence later through JS. I am using the following JS to set the sequence :
$scope.view.wdg['model-1']['sequence'] = 'l-Creo 3D - Figure 1.pvi'; ,
Now, While it works for only one sequence, the same does not work when I call Figure 2.
2. Second issue is that, Figure 2 is a Dis-Assembly snapshot, for some reason, the minute the experience is launched, the model locks into the Figure2 View and hence starting in the Dis-Assembly view which is not intended.
Somebody pl help!!!!
Avinash
I have some questions :
Without it, it will be difficult to debug that.
Best regards,
Samuel
Hello Avinash,
Best regards,
Samuel
