Iterate through all the widgets available in a view by code.
Radu
Hi.
I want to iterate through all the widgets available in a view through JavaScript. I can access the list of all the widgets through this:
console.log($scope.view.wdg);
I observe that this is in JSON format. However, when I do
console.log(Object.keys($scope.view.wdg).length);
, which would return the number of keys in a JSON object, it logs "0".
Has anyone iterated through all the widgets available in a view before? If so, any help would be appreciated.
Thank you.
Hi @Radu
different way to do this - here one example:
 var wdgs=$scope.app.view.Home.wdg;
  for(wdg in wdgs)
  {  console.warn(wdgs[wdg])
      for (prop in wdgs[wdg])
           console.warn(prop+":"+wdgs[wdg][prop])
this will print for all widgets in the home view all properties
Hi @Radu
  for(wdg in wdgs)
here another way:
$scope.app.modelWdgListCreate= function(){
  var wdgs=$scope.view.wdg;
  if($scope.DEBUG){
  console.warn ($scope);console.warn(wdgs);}
retList=[];
  Object.keys(wdgs).forEach(function(key) {
    var wdg = wdgs[key];
    if (('sequence' in wdg)==true){//is a model widget
      const objToadd={name:wdg['widgetName'],file:wdg['src']};
      //retList.push( objToadd);// in this case will create json
      retList[wdg['widgetName']]=objToadd; //this will make arr with index=nameId
$scope.seqMdlListArr= retList;//set the $scope list variable
if($scope.DEBUG) console.warn($scope.seqMdlListArr);
$scope.$applyAsync();};
In this example above I create form the widget a list only for the widgetNaem and the source property. It checks and handled only widgets which have a sequnece property
here the code I reset the src and the sequence of widgets
// will reset the src and sequnece if was set
$scope.app.modelWdgReset= function(){
 wdg = wdgs[key]
       if($scope.DEBUG) console.warn("=>modelWdgReset key="+key)
       $scope.setWidgetProp(key,'sequence','')
       $scope.setWidgetProp(key,'src','')
       $scope.setWidgetProp(key,'visible',false)
  //    wdg['widgetName'].sequence ='';//set it to undefined
  //    wdg['widgetName'].src='';//set it to undefined
  //    wdg['widgetName'].visible=false;
