Lagging/Slow Experience on Hololens
mbiegel
Hi Community,
I want to create an experience on hololens with an animated sequence. The PVZ file is not big at all (~13MB), but the experience is really slow and lagging - the model is loaded very slowly and the animation just works randomly and slow. Maybe the CAD is to complex ( too many polygons?). Does anybody have a solution to solve this issue? That would be great.
Thanks in advance
Marco
tmccombie
(To:mbiegel)
Hi Marco,
When you imported your pvz file, did you run the CAD optimizer? If not, I would suggest running the optimizer and choosing the medium or low pvz resource. As a best practice, models should be limited to 200,000 polygons.
Hi Tara,
sorry, I did not mention. Yes, I´ve used the CAD optimizer and worked with the lowest output, but it did not help. Do you have a tool on your mind to reduce the number of polygons?
Thank You!
Marco
tmccombie
(To:mbiegel)
Hi Marco,
You can find the number of polygons within your model following the instructions in this thread: How to count number of polygons in a pvz file
Also check out slide 44 in the AR best practices guide for some additional optimization options.
Thingworx Studio - AR Best Practice
