Layer item from pvz are not shown in Creo Illustrate and Studio
amulay
7-Bedrock
I have created pvz which contain some layer with texture scale as shown in attached image. The layer item is shown correctly in Creo View however when we retrieve the pvz in Creo Illustrate OR Vuforia Studio then it is not shown. Whether I am missing some setting here OR it is not supported in Illustrate and Studio?
dupatel
(To:amulay)
@amulay I believe the feature is not supportable however it will be good if you can open a PTC Support case to investigate and raise an enhancement request  if not already existing.
-Durgesh
dupatel
(To:amulay)
-Durgesh
