Making visible 3D label with JS
flamy
How to make a 3D label visible with a javascript ?
~ Francois
katte
(To:flamy)
Please follow the below JS function to hide/show the 3D label:
$scope.hideLabel = function(){
  $scope.view.wdg['3DLabel-1']['visible']=false;              //Hides the 3D label
$scope.showLabel = function(){
  $scope.view.wdg['3DLabel-1']['visible']=true;            //show label.
You can write this code in home.js and make a call to the corresponding function. For example, in the above case provide the name of function under button click 'JS' space i.e., "hideLabel()" . So that when a button/widget is clicked it performs the action defined in the function.
katte
(To:flamy)
flamy
(To:katte)
Thanks .. working great . .will now continue in building my demo for LiveWorx 🙂
Do you have a recommendation on where I can get more info on the different functions like view.dwg .. etc .. available in Studio ?
I am trying to learn going through the different postings .
~ Francois
katte
(To:flamy)
Yeah we've provided sample JS tutorial at help centre JS tutorials ​where we have listed few functions and parameters for the widgets, app parameters, properties etc., I guess that should provide a greater insights on using JS in Studio.
