How to rotate a model along the Z axis like in CAD applications? Model created is having axis of rotation outside the model. I am using slider to rotate the model.
Dhinesh
i got this issue.
what u can do is u can change the axis of model in creo or in any CAD modelling software and shift the axis to centre of model and import in vuforia studio.
By doing above changes in modelling software it will suffice your requirement.
1. A similar question was recently - "Is it possible to rotate a 3d object with your finger?": https://community.ptc.com/t5/Vuforia-Studio/Is-it-possible-to-rotate-a-3d-object-with-your-finger/m-p/757157#M10321
2. Another one - "Rotating the 3d model": https://developer.vuforia.com/forum/ios/rotating-3d-model
Hi Vladimir,
I did check these links before starting this thread. They are not addressing my issue.
Hi @MSD2 ,
The behaviour shown in the video is strange, as in my quick test, my model rotates from the center.
Would it be possible to share with us the model? I currently don't have a clue, what the issue might be.
Thank you for your understanding.
Mcotora
Hi Mcotora,
Here is the link to download model - https://drive.google.com/file/d/1UOzeq0DKCfc3x-rlp3s0F1Z8FBtgwoI8/view?usp=sharing
i got this issue.
Hello @MSD2 ,
the problem is based on the model root coordinate system. IN your case the root assembly coordinate system is not defined on the location where you want to rotate. So to solve this problem you have the following options:
