Navigate service throw Uncaught BindingError
nqwifly
I'm trying to navigate from a view to another, I dragged click event of a button to the desired view. When I tested it on Preview page, I got:
libthingview_wasm.js:1
Uncaught BindingError {name: "BindingError", message: "Cannot pass deleted object as a pointer of type Session*", stack: "BindingError: Cannot pass deleted object as a poin…extensions/js/twx-mobile-widgets-3d-ng.js:3971:17"} message: "Cannot pass deleted object as a pointer of type Session*" name: "BindingError" stack: "BindingError: Cannot pass deleted object as a pointer of type Session*↵ at BindingError.<anonymous> (http://localhost:3000/resource/Project%20Alice%20Vuforia/dist/extensions/js/libthingview_wasm.js:1:133001)↵ at new BindingError (eval at createNamedFunction (http://localhost:3000/resource/Project%20Alice%20Vuforia/dist/extensions/js/libthingview_wasm.js:1:131888), <anonymous>:4:34)↵ at throwBindingError (http://localhost:3000/resource/Project%20Alice%20Vuforia/dist/extensions/js/libthingview_wasm.js:1:134582)↵ at RegisteredPointer.nonConstNoSmartPtrRawPointerToWireType [as toWireType] (http://localhost:3000/resource/Project%20Alice%20Vuforia/dist/extensions/js/libthingview_wasm.js:1:150127)↵ at Session$GetRenderStats [as GetRenderStats] (eval at new_ (http://localhost:3000/resource/Project%20Alice%20Vuforia/dist/extensions/js/libthingview_wasm.js:1:158648), <anonymous>:7:28)↵ at http://localhost:3000/resource/Project%20Alice%20Vuforia/dist/extensions/js/twx-mobile-widgets-3d-ng.js:3971:17" __proto__: Error throwBindingError @ libthingview_wasm.js:1 nonConstNoSmartPtrRawPointerToWireType @ libthingview_wasm.js:1 Session$GetRenderStats @ VM9902:7 (anonymous) @ twx-mobile-widgets-3d-ng.js:3971 setInterval (async) addRenderStat @ twx-mobile-widgets-3d-ng.js:3970 cvApiReady @ twx-mobile-widgets-3d-ng.js:167 (anonymous) @ twx-mobile-widgets-3d-ng.js:177 (anonymous) @ thingview.js:18 (anonymous) @ thingview.js:181 _loadPreferences @ thingview.js:299 LoadPreferences @ thingview.js:180 onRuntimeInitialized @ thingview.js:12 doRun @ libthingview_wasm.js:1 run @ libthingview_wasm.js:1 runCaller @ libthingview_wasm.js:1 removeRunDependency @ libthingview_wasm.js:1 receiveInstance @ libthingview_wasm.js:1 receiveInstantiatedSource @ libthingview_wasm.js:1 Promise.then (async) doNativeWasm @ libthingview_wasm.js:1 (anonymous) @ libthingview_wasm.js:1 (anonymous) @ libthingview_wasm.js:1
Kept throwing forever until I close the page.
Any clue about what cause the problem?
sdidier
(To:sdidier)
Just for information, Jira ticket is DT-21042 about this issue.
This article has been created :
https://www.ptc.com/en/support/article?n=CS301350
Best regards,
Samuel
4 REPLIES 4
sdidier
(To:nqwifly)
I made a similat test as your description in Vuforia Studio 8.4.0.
I am not able to reproduce this issue.
Please find below the Project.
Try to import it in you Vuforia Studio and check it.
  • What is the result ?
Another question, what is the binding created from click event in Button and the second View?
Is it Naviagte, Show Modal or Hide Modal ?
Last question, can you share the Project where you have the issue ?
I would like to test it locally in my workstation.
Best regards,
Samuel
nqwifly
(To:sdidier)
Now I can see the error only thrown when I use 3D widget to navigate to another view.
Answering your question, binding is: Naviagte
Please check the attached project (same as yours, but added a 3D play button to navigate). Same Uncaught BindingError is thrown.
sdidier
(To:nqwifly)
Thanks you for your feedback.
Now, I able to reproduce the issue in my Project.
From my point of view, it is a bug.
So, I am reporting it to R&D.
Best regards,
Samuel
sdidier
(To:sdidier)
Best regards,
Samuel
