Dear all,
Need one crucial information on Thingworx AR approach related to software whichever part of this approach.
Quite confusion between overall Thingworx Software like
Among which one is helpful for AR approach?
@p3 Yes, you can select the ThingWorx + Navigate option to download the required license.
If above response(s) has answered your question, please mark it as the Accepted Solution, for the benefit of others who may have the same question.
-Durgesh
@p3 For AR solution, you will mostly be using ThingWorx Platform feature and capability to get real time data from external system which could be integrated into your AR experiences.
-Durgesh
Dear Durgesh,
Thanks for your valuable reply.
Pranet
@dupatel one more confusion related to Licensing of Thingworx, I can see these many options only is it sufficient??
As I'm not able to see ThingWorx Platform Licenses.
Your reply is appreciable.
Pranet
@p3 There is a separate portal for License download - https://support.ptc.com/apps/licensePortal/auth/ssl/index
You will have to select the ThingWorx version and enter details to get the license file.
-Durgesh
Thanks @dupatel,
I can see only 3 entries as shown below.
Is it sufficient for ThingWorx+Navigate only? or We can use same License file for Thingworx Platform?
Pranet
-Durgesh
