I am not able to open Studio .
error: System.IO.DirectoryNotFoundException: Could not find a part of the path
In local antivirus software remove Studio.exe files from the quarantine and re-install the studio.
Ketan Singh
Ketan Singh
Okay will check.
Thank you
Can you please confirm if the solution works for you?
Ketan Singh
