I've been trying to reference a widget the first time a view is opened, but when I do the console logs it as undefined. For a view, are widgets defined after the first time the js runs? Thank you
Hi @cmodin ,
I think the problem is here as your correct mentioned in your post is that when you try to use references of object they are no loaded yet.
So the solution is simple . You can call you code in a function of some events
For referring to 2d widget you can use the $ionicView.afterEnter event. When this event is called all 2d widget are already loaded and could be accessed by javaScript
Example:
$scope.$on('$ionicView.afterEnter', function() {
$scope.view.wdg['image-1']['imgsrc']="app/resources/Default/vu_fuel-pump.svg";
For 3d Widget (model widgets and modelitem widgets) you can use the modelLoaded event
example
$rootScope.$on('modelLoaded', function() {
$scope.view.wdg['modelItem-door-aus']['forceHidden'] = true;
$scope.view.wdg['modelItem-door-aus']['visible'] = true;
$scope.view.wdg['slider-2']['value']=0;
$scope.view.wdg['modelItem-door-aus']['forceHidden'] = false;
Of course there is also possible to use other events but also the $timeout() service. So, you can call a function with delay, but this is something where we are not sure how long should be the delay and in some cases because hanging of device or loading of more complex model this could fails.
Hi @cmodin ,
Example:
example
