I have one physical model. That's assembly. I'm now positioning the model using the model target. If the assembly is appropriately positioned but a part is missing or part not placed properly. it should highlight the item part not placed properly.
Is that possible to do that in Vuforia studio.
Hi @Rakesh_kumar_S ,
I am not sure if I understand correctly your question.
- so you have a model target, when you create it you will see that if it is displayed correctly or something is missing
or where the problem part? Is that in the augmentation 3 D model or is the object what you scan?
Could you provide here more details?
So in generally to have more robust design if the augmentation will change you can use different apprearance of that model
- a simpliefied model for the model target which is then on runtime hidden
- your augenetation where you will have e.g. different states of display - so for example some components are hidden or there is some plays of sequences
Where should be the wrong component - is that waht you meant a difference between augmentation model and real model - is that what you want to check? So far I know currently there is only possible that user will compare that on view and check if he /she could recognize any differences
