How do you play certain steps in .pvz file with only 1 button?
Example, when button is press, step 1 will animate. When the button is pressed the second time, instead of going to step 2, step 3 will animate.
Hello Jeremy,
The solution is to create a Javascript function to play the next step wanted.
For example, please see these threads :
Of course, the source codes provided don't match your needs exactely.
It is needed to be modified.
Best regards,
Samuel
Hello Jeremy,
Best regards,
Samuel
