I have always used Postman to delete the published experiences, but lately I received this kind of msg, which does not allow me to cancel the experience, from what can it depend? the configuration parameters are the same used until everything worked.
What has changed ?
Resolved.
unlike before you must also add the parameter
X-Requested-With : application/json
Resolved.
