I have admin privileges on my machine and have never had a problem installing other applications, but this is what I get when I try to install Thingworx studio.
I've gone through installing the certificate and still no luck.
Any ideas what setting is causing this or what else I can try?
I found the solution, WOW needed to make edits to the registry to get it to install.
