Stuck on initializing project after importing project
Henu
3-Newcomer
After succesfully importing a project, it gets stuck on "Initializing project" when opening it. If I refresh the browser, it opens the project but it is empty. I am using Vuforia Studio as an administrator. Here is the log:
[2019-11-13T18.19.51.459Z] Studio 8.5.1.4496
[2019-11-13T18.19.51.471Z] Status Message: Getting ready...
[2019-11-13T18.19.51.471Z] Starting node.exe
[2019-11-13T18:19:55.982Z] info: [twx-studio:index] Studio Version 8.5.1.4496
[2019-11-13T18:19:56.185Z] info: [twx-studio:initializer] Node version: 10.15.3
[2019-11-13T18:19:56.192Z] info: [twx-studio:initializer] studio launched with the following arguments: { _: [ 'C:\\Users\\hkuiv\\Documents' ],
'$0':
'..\\..\\..\\..\\..\\..\\Roaming\\VuforiaStudio\\studio-download.vuforia.io\\dist\\server\\index.js' }
[2019-11-13T18:19:56.194Z] info: [twx-studio:initializer] studio dir: C:\Users\hkuiv\Documents\VuforiaStudio , home dir: C:\Users\hkuiv\Documents
[2019-11-13T18:20:04.232Z] info: [twx-studio:gitUtils] nodegit is not installed.
[2019-11-13T18:20:04.324Z] info: [twx-studio:ar-extension:upgrade] ar-extension version 8.5.1.4496 (1.44.1627)
[2019-11-13T18:20:07.868Z] info: [twx-studio:versionCheck] Version Check will use the update location: https://studio-download.vuforia.io/downloads/Studio.application
[2019-11-13T18:20:07.881Z] info: [twx-studio:index] Studio Ready: listening on localhost:3000
[2019-11-13T18.20.07.881Z] Status Message:
GET /api/projectTemplates 304 33.131 ms - -
GET /extensions/%7B%7Bctrl.projectDefinition.typeIconPath%7D%7D 404 1.874 ms - 197
GET /license-agreement-url 404 1.912 ms - 160
[2019-11-13T18:20:13.202Z] info: [twx-studio:versionCheck] version check complete 8.5.1.4496 8.5.1.4496 true
GET /api/version/check 200 612.148 ms - 76
GET /api/projectTemplates 200 5.601 ms - 271
[2019-11-13T18:20:21.645Z] info: [twx-studio:versionCheck] version check complete 8.5.1.4496 8.5.1.4496 true
GET /api/version/check 200 386.718 ms - 76
[2019-11-13T18:20:27.637Z] info: [twx-studio:projectSettings] fileName "undefined" did not match location "3DSTemplate" for project named "undefined". The fileName and name will be changed to match location.
PUT /api/project/import/?name=3DSTemplate 200 2244.267 ms - -
[2019-11-13T18:20:32.758Z] info: [twx-studio:upgrade:3DSTemplate] Upgrading project
[2019-11-13T18:20:32.925Z] warn: [twx-studio:upgrade:3DSTemplate] C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\src\phone\components\Home.json
[2019-11-13T18:20:32.926Z] error: [twx-studio:upgrade:3DSTemplate] Unable to update the metadata.json file, it was not found at C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\src\shared\components\metadata.json
[2019-11-13T18:20:32.927Z] warn: [twx-studio:upgrade:3DSTemplate] Wasn't able to migrate the data in view
[2019-11-13T18:20:32.928Z] warn: [twx-studio:upgrade:3DSTemplate] Wasn't able to migrate the data in view
[2019-11-13T18:20:32.929Z] error: [twx-studio:upgrade:3DSTemplate] File not found during migration of handler to handler-path
[2019-11-13T18:20:35.148Z] info: [twx-studio:upgrade:3DSTemplate] Building ves-ar-extension app:
[2019-11-13T18:20:37.227Z] error: [twx-studio:ar-extension:gulp-shared] C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\src\phone\components\Home.json does not exist
[2019-11-13T18:20:37.240Z] error: [twx-studio:index] unhandledRejectionENOENT: no such file or directory, open 'C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\dist\app\components\Home.html' { Error: ENOENT: no such file or directory, open 'C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\dist\app\components\Home.html'
at Object.openSync (fs.js:438:3)
at Object.readFileSync (fs.js:343:35)
at addEscapedInlineHTML (C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\gulp-shared.js:1432:21)
at C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\gulp-shared.js:454:17
at arrayEach (C:\Users\hkuiv\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\lodash\lodash.js:516:11)
at Function.forEach (C:\Users\hkuiv\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\lodash\lodash.js:9342:14)
at C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\gulp-shared.js:453:17
at process._tickCallback (internal/process/next_tick.js:68:7)
errno: -4058,
syscall: 'open',
code: 'ENOENT',
sdidier
(To:Henu)
Hello Henu,
It seems Vuforia Studio has problem to open some files.
  • What do you have in the folder C:\Users\hkuiv\Documents\VuforiaStudio\Projects\3DSTemplate\src\phone\components ?
  • Did you do a backup of the Project folder ?
Best regards,
Samuel
Henu
3-Newcomer
(To:sdidier)
There isnt a components folder in src\phone, only a resources folder. I believe the project im trying to import is made on an older version since the folder structure differentiates so much from the projects I have made with the latest version. Here is a screenshot comparison of the folders: https://paste.pics/da1a5cd73136e93bf51d8d6abe405b4a
I haven't done a backup of the Project folder
Is there a way to rearrange the contents of the project im trying to load so that it would open correctly?
sdidier
(To:Henu)
I have a look of the screenshot.
It is a screenshot of the Project folder at the root level.
Please go in src/phone/components folder.
In Screenshot, Project named Coffee_Maker_Project has the right folder name.
Project named 3DSTemplate doesn't seem a Vuforia Studio Project.
Best regards,
Samuel
sdidier
(To:sdidier)
  • Where do you find this 3DSTemplate Project ?
Best regards,
Samuel
