Hi everyone,
in my project some dropdown menus are used for some selection.
Basically I want to style the hover on them with some CSS script.
I'm trying to follow this guide: https://www.w3schools.com/css/css_dropdowns.asp
but never happens to my dropdown widget.
Anyone could help me?
At first check if your custom CSS class is applied correctly on AngularJS element.
Please follow these steps :
At second, override CSS classes needed.
Best regards,
Samuel
Hi @LS_9776545,
I checked the guide link what your mentioned in your post: https://www.w3schools.com/css/css_dropdowns.asp
I think this could not work because it is css definition regarding to specific html definition
<div class="dropdown">
<span>Mouse over me</span>
<div class="dropdown-content">
<p>Hello World!</p>
</div>
</div>
we can see -> there are required 2 classes to get the desired behavior and this is not directly applicable for a widget - where we used only one CSS class definition.
If we change it to something like:
.dropdown:after {
position: relative;
display: inline-block;
content:"Button1"
.dropdown:hover:after{
content:'HOVER ACTION DONE on Button1';
.dropdown:hover {
position: relative;
left: 15px;
top:20px;
border: 3px solid #73AD21;
background-color: #f9f9f9;
box-shadow: 0px 8px 16px 0px rgba(0,0,0,0.3);
padding: 55px 55px;
z-index: 1;
It is not perfect but should display the principle
You need in this case only one css defintion class what you can set to the class property of the button widget. Here it adds also the text - the Button Text property is empty:
Short remark – the however event is working on tablet e.g. IPad but it is not a real event intended for this device – is some thing more for device with mouse. But in generally it work. When you tab on the button it will apply the hover – and then if you click on it will start the button action but will not close the hove appearance. To finish it you need to click anywhere outside the button area.
ok, thank you for the answer.
So, I want to modify the style of the dropdown menu and, more important: when I hover on the dropdown I want to show all the options contained in it.
Hi @LS_9776545 ,
I think the resource your mentioned in your previous post https://www.w3schools.com/css/
is a very good start point to learn css and for the implementation of the menu functionality. To find the best approach it requires some test to find out what is the best behavior in Studio
So when we check the info on:
https://www.w3schools.com/css/css3_buttons.asp
https://www.w3schools.com/howto/howto_css_dropdown.asp
https://www.w3schools.com/howto/howto_css_icon_buttons.asp
and combine the described techniques - then we can create some buttons which will behave as menu.
I tested something in a small project where combined a css styles acting with the hover event and the panel and button widget. Tested in preview mode and on IOS - was working fine.
Depending on that what you intent to implment the css definition could be more complex
Here I attached what I tested in a demo project to this post . You can check the widget properties and the setting css definition in the app.css section (Studio Application). I hope, may be , this could be helpful for you.
