Is there any way to use animations from Maya in ThingWorx studio? And if not, is there any way I can export a 3D model from maya and animate it using other software?
@JonathonFowler : Request to please refer Studio Help page to get list of supported file format with ThingWorx Studio.
-Durgesh
@dupatel I have already looked through this. So is there anyway I make custom animations for 3D models? If so what software and tutorials do you suggest I use? There doesn't seem to be any information on making animations, just this tutorial which uses a pre-built animation.
-Jon
@JonathonFowler: Creo Parametric 3D Modeling Software is one of the PTC product which is could be used to create 3D content.
Creo Illustrate is used to Create 3D illustrations from existing engineering files.You can click the product links to explore more about them.
Hope it helps.
-Durgesh
