Vuforia Studio Compatibility - Windows Server 2022
Alex_Usatai
Good morning, everyone.
Sorry to bother you, but I would like to ask a question regarding the Vuforia Studio and its compatibility with the OS Windows Server.
Is it possible to install Vuforia Studio on a Windows Server 2022, please?
The context is that I was trying to install Vuforia Studio 9.25 in a Windows Server 2022, and in the same machine is installed the Experience Service with Thingworx, and I would like to have Vuforia Studio and Experience Service on the same computer. However, I could not manage to boot the installer because of the extension appxbundle, and after that, I went to the Help Center to see the compatibility with the OS, and it said that it was only compatible with Windows 10 and 11, and to be sure, I would like to ask if it's possible and if there is a way to install it on a Windows Server 2022.
Thank you very much,
Kind Regards,
Alex Usatai
Alex_Usatai
(To:VladimirN)
Good Afternoon Mr. Vladimir, how are you?
Thank you very much for the solution, it worked. And sorry for taking so long to respond.
I was using a Windows Server 2022 and I opened the power shell console and used the following command:
Add-AppxPackage -path "C:\MED\xxxxxxxxx.appxbundle"
Best Regards and Thank you,
Alex Usatai
