Vuforia Studio error starting node.exe
JennieFo
7-Bedrock
[2019-11-12T01:15:38.759Z] Studio 8.5.1.4496
[2019-11-12T01:15:38.801Z]状态消息:正在可行...
[2019-11-12T01:15:38.801Z]起始节点.exe
[2019-11-12T01:15:39.107Z] ---错误的启动node.exe ---
[2019-11-12T01:15:39.110Z] System.ArgumentException:已添加项。 :“ NODE_PATH”所添加的关键字:“ NODE_PATH”
在System.Collections.Hashtable.Insert(对象键,对象nvalue,布尔值添加)
在System.Collections.Hashtable.Add(对象键,对象值)
在System.Collections .Specialized.StringDictionaryWithComparer.Add(String key,String value)
在com.ptc.ThingworxStudio.MobileBuilderForm.StartServer()
[2019-11-12T01:15:39.110Z] ----
yes , i deleted  PATH_NODE,and  solved  this problem
dupatel
(To:JennieFo)
@JennieFo  Could you please confirm if there is any other version of external Nodejs installed already?
